Porsche Factory Sat Nav Install
- Thread starter jonc4s
If you want to get a Porsche warranty then retrofitting PCM2 is your ONLY option for SatNav, apart from a portable system - TomTom and the like. If the warranty doesn't bother you, then an aftermarket double-DIN satnav system will give you far better functionality than PCM, but is harder to integrate into the car. Basically, you would have to remove the fibre optic components of the Porsche radio and start again. Still far cheaper than PCM2 though.
If it is an earlier C4S (non-MOST) aftermarket kits are much easier to install - almost plug & play. As far as I know, PCM1 retrofit kits are no longer available, so if you really wanted one then you would have to source a second hand unit.
Once again for the usfel information on the kits and costs.
Jon,
I have a PCM1 on my car and I like the way the whole unit it integrated with other functionality such as fuel economy, range and various other useful functionality etc.
However, the Sat Nav is a bit dated (even PCM2 excluding the very latest 997 type) dont have birds eye view etc. And, the buggest bug bear for most Porsche owners is that the updated Nav disks are either no longer available and supported by Porsche or are incredibly expensive. Its actually cheaper to buy a brand new Tom Tom than an updated disk!!!!!!
Saying that, if I were to buy a new Porsche I would almost certainly want one with an integrated Sat Nav!
All the best,
Rob
jonc4s
Beershark - I have a PCM1 on my car and I like the way the whole unit it integrated with other functionality such as fuel economy, range and various other useful functionality etc. Exactly what I like to see in my cars, essential to me really.
I have heard this elsewhere that they aren't the best, can you get hold of copied disks with the updated maps or is there security blocking this? My problem with TOMTOMS is that I like my SAT NAV to be integrated so I think my only option is to just sit tight until I find an example with my desired spec, and price of course!
From what I understand on other posts here and on Rentech, Porsche no longer supply the updated disks for earlier PCM's and they will not allow the other disk manufacturers / suppliers to supply disks either.
Somewhere on the forum there were some articles about disks for (possibly) Vauxhalls worksing but I have never tried that myself. If you end up with a PCM then it my be worth looking at.
However, I do agree with Richard that retro-fitting a PCM would not be as comprehensive or good value as an aftermarket option and I would sacrifce some of the original car functionality for enhanced Sat Nat etc.
Didnt know that - thanks for the update. I will check the cost out for both and maybe do an update.
Do you know if they will both work on the 8 bit unit, I thought the Opel maps were for 16 bit only when I saw a thread some time ago?
I understand from the Rentech thread that I would have to upgrade the Sat Nav as well using an upgrade disk, do you know if this gives any further functionality?
Thanks,
Rob
The chap to speak to about the Opel disks is Gil Keane at Satnavshop/Quicksilver Automotive on 0121 773 7000 or 07973 216682. I'm pretty sure he does the maps for the 8-bit version, and can supply the software update CD. I don't think it gives you any additional features though.
