Perhaps someone can advise here?
I have bought a set of 20mm spacers that fit on the rear fine but won't slide over the central boss of the front hubs.
it appears that the spigot that sits proud of the spacer and locates the inner of the alloy wheel is the same size as the spigot on my front hubs.
I do need another set of spacers to complete car and are concerened I may buy others that won't fit also. I could have the central bore of the spacers machined out so that they fit the front but wonder if a set which bolt to the wheel hub and have other wheel studs for the wheel to locate may suit.
I also believe the problem may be cause by the hub allready having spacers fitted as the hub assembly looks very different to my experince with motors. They may be just typical 944 setup but as I'm not terribly experieneced with these I just can't comment.
could people look at the front hub picture below and decide how I can fit some 1" spacers to them.
cheers all
cheers all
