Possible damaged window mechanism
chriscoates81
Hi guys, tonight when i got in my car i noticed the window didnt pop down when i pulled the handle so i had to jiggle it a bit to get in. I thought it might just be due to it being cold this morning when i parked it (around 0 deg or so), but as i was driving home i tried the passenger side which worked ok. I tried the drivers side again and it just makes a kind of whiring noise then when i got on my drive and got out it didnt pop up or down. Have I damaged the mechanism or is it somthing simple?
^^^ Wot he said. See my last running report [link=http://www.porscheclubgbforum.com/tm.asp?m=598771]here[/link] for details of how I saved £££ by getting my local indi (Autostrasse) to fix mt broken window regulator, rather than the £502.52 my OPC wanted !
This happened to me when I left the passenger window open for a couple of weeks with the car unused. When putting the window up fully, and shutting the door it would make a wining noise like it was trying to still shut the window. I'm not sure of the documented procedure to reset the drop facility, but on my wifes mini which had a similar issue I had to put the window all the way down then hold the button up for several seconds after it was fully closed to reset. I tried the same thing on the Porsche thinking it may have a similar system and it worked lol.
ORIGINAL: steveoz32 This happened to me when I left the passenger window open for a couple of weeks with the car unused. When putting the window up fully, and shutting the door it would make a wining noise like it was trying to still shut the window. I'm not sure of the documented procedure to reset the drop facility, but on my wifes mini which had a similar issue I had to put the window all the way down then hold the button up for several seconds after it was fully closed to reset. I tried the same thing on the Porsche thinking it may have a similar system and it worked lol.
So i should try to move the window down then press the up button and hold it?
Just incase anyone has this happen it was the wire that had snapped. There was no membrane whatsoever though is there one usually?
Oh i see when membrane was mentioned i assumed you guys ment a plastic. The foam is there i just assumed it was a sound dampaning material.
