Hi, got a problem where the coolant on my 84' 944 is backing out the expansion overflow once the car gets up to normal operating temp.
There's a also a kind of squeaking sound coming from around the front of the engine after we let her idle for a while.
Things we've checked/changed so far:
1. Checked oil filler and dipstick for milky oil = Oil looks fine and level was in the middle between min and max.
2. Pressure tested coolant system = No leaks found
3. Changed old thermostat (2 years old) for a brand new one from Porsche = Same problem with coolant backing out.
4. Removed the alternator belt and power steering belt = Squeaking still happens
Are there any other things I should check that will confirm or eliminate some possibilities?
Also does anyone know a good independent Porsche mechanic in the Kent area?
Thanks in advance.
Thanks in advance.
