Hi
My Carrera sport came with two Blaupunkt bridge amps under the drivers seat (not quadro's but a pair of 100W bridge amps).
Should these have been installed on a plate screwed into the mounting bosses ? The installation in mine looks to have been butchered by the original owners installer (Mr A911RAT
). They were screwed into the floor such that now I can see the road through the holes and each were only secured at one end !. The proper bremen SQR amp cable had been used (911 612 196 00) but with some speaker cables cut and two extra ones run externally.
I also have two more speaker wires under the dash which I suspect come from the smaller 'pod' style speakers in the doors rather than the big Alpine speakers. Should both door speakers be wired together ?
I have taken everything out (including the connections for the 80's car phone but would like to put the Amps back if I could get the correct parts (or was it fairly DIY anyway) ?
I am installing the SQR46 DAB but I am also returning all the wiring to standard, cloth wrapped so the original radio can be reinstalled whenever required. It already looks so much better under the dash now all the chocolate box connectors, and shiny electricians tape have been removed. Just need to patch up the holes.
