The power hood on my cab has recently failed. It is in the raised position so no probs driving the car. When the switch is pressed to lower the hood nothing happens. There is no noise from the gears, rams or motor. When the switch is pressed to raise the hood, the side windows slide down as expected. This fault developed at the same time as my indicators went on the blink- easily cured with a new relay. I have checked all the simple electrical fuses and relays and these seem OK. This has been confirmed by my OPC when the car was in for new belts and annual service. They did not have time to chase the fault in the hood stating it would require "commitment level investigation". Anybody out there experience similar probs with either 944 or 968 cabs? Any advice would be extremely useful.
Thanks, Tim.
Thanks, Tim.
