Power Hood
- Thread starter jag45
dereksharpuk
What is important is the care of the hood and, more importantly, the care of the perspex window if the have an older version. Do not raise/lower it this weather. Keep it clean. If you have a hard top in place, raise the fabric hood a few times in winter if the weather is not too cold. Make sure when you do lower the hood that the perspex window folds neatly (if necessary, stop half way and use the side of your hand).
dereksharpuk
On a diferent note, I see that you are new to this forum and a guest of the Club. Why not join? You will get the best monthly magazine available, totally free of charge and 10% off OPC servicing. More importantly, meet great like minded blokes and be able to attend a vast and varied amount of Porsche events.
What can happen on a glass-windowed roof? The drive cables can break - they work a bit like those that drive windscreen wipers, and if one breaks the hood will start to raise/lower crooked - if this happens DO NOT use the motor to continue raising/lowering, it will twist the frame and that's going to be expensive... But this isn't exactly common either!
Everything else is just wear and tear - tension cables detaching or breaking, cloth wear, cosmetic waterproofing.
Don't worry about it and drive it
