power inverter
Ash944
Hello all
Iv just got a garage but it has no power. But I'm mid way threw replacing the cills got one side done
I'm looking at getting a generator to power the welder does anyone recommend one iv seen a few out there. But I'm unsure what to get really. Don't want to get one which aint powerful enough
The rules are simple-ish, but generator power is dirty, so Im not sure how well you can weld using it. Generators whith a sufficiently high output and a clean output sine will be extremely expensive. You can use a sine inverter, sometimes called a 'smoother' or 'smooth unit, but Im not sure about their cost.
Look at the plate on the welder: it will have to state its peak load and will say something like 1,800 Watts, or 1.8 KiloWatts.
Because electrical equipment can take double its rated current upon start-up, you are now looking for a generator rated at 3,600 Watts, or 3. 6KiloWatts at the absolute minimum.
Just to make it a little harder, generators are rated in KVA. Roughly, 1KVA = 0.8KW (so 2.4KVA = 1.92KW & 3KVA = 2.4KW etc). http://www.dieselservicea...alculator.aspx#kvatokw
