Power steering fluid
Waylander
Dexron II is what it says in the manuel http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/car-tranmission-oils/automatic-transmission-fluids/?522776082&0&cc5_869
>>edited: This applies to 944S and possibly S2, so other 944 don't have the switch fitted on the PAS pump. Please read my issue "WARNING PAS pump... reconnecting the PAS switch or if the cables short at the plug end it "will" fry your loom, I have posted my unfortunate time reconnecting said plug to the PAS switch, I found this on my 944S as it was disconnected, I reconnected it and I shouldn't have as its a known risk if it shorts out will burn part of the loom out....this is my problem now. Importantly I hope my thread generates responses best how to prevent it happening to others and what to do if it unfortunately happens and how to replace the burnt cabling !!
