Hi Folks
I think I have a problem with the power steering pump on my 1989 944S2 Cab. With engine running there is a noise/groan coming from the pump, with NO pressure applied to the steering wheel. If I of apply a small amount of pressure or turn the steering wheel the noise/groan will stop until I release the pressure on the steering wheel and then it will start again.
Eventually after a lot of cursing, I have managed to remove the PS pump. Previous owner/mechanic had not used the correct long support bolt. Just a but of threaded bar.
Is the pump repairable?
Any Ideas?
cheers
John
Any Ideas?
cheers
John
