pixie*porsche
Found my rack is leaking power steering fluid from my 1984 square dash 944. I stripped it off the car today.
Not really sure what to do - whether to keep the power steering system or convert to a manual rack, does anyone know what would be involved in this conversion?
I believe that the steering shaft is the same but the rack itself, track rods and ends are all different. What I want to know is if the cross member / 4 mounting points for the rack are the same and I also need to know if the arms on the stub axles will take the manual type track rod ends.I also need to know if the splines on the input shaft of the manual rack will match the splines on the UJ fitted to the bottom of the steering shaft.
If anyone has done the conversion from power to manual or manual to power I'd love to know your thoughts.
