Power Steering
- Thread starter Guest
wedgepilot
Diver944
This is one of those ' they all do that' stories. Both of mine groan very occasionaly when the car is on full lock and reversing out of the driveway. Some people report their groan has gone away simply by replacing the power steering fluid (it has probably been in the car for over 15 years anyway), whereas other have had success by rebuilding their power steering pump using the kit that was featured in ' 911 and Porsche World' recently.
I' m quite happy to live with my groan, it' s been there the 5 years we' ve had the S2
Hope this is of some use.
944cabby
Wizard, does this pipe run directly under the engine or in front in the bumper area?ORIGINAL: wizard
I recently a similar issue with mine but fortunately it was not the rack. There is a high pressure pipe that runs across the bottom of the engine, it has a shroud around it and fluid was leaking out at the ends, I think the pipe was split. I took it to Northway to have a look at - they have a guy on the industrial park who makes up high pressure pipes at a fraction of the cost of the origional.
peanut
A garage down in Devon that shall remain nameless wanted to replace my pump some years back. When i checked I found that the leak came from the hose clip beneath the reservoir[
If the leak is from your steering rack it is possible to get service kits to replace the seals
petrolhead944
Peter Empson
944cabby
I get something similar as i reverse my cab out of the garage and turn the steering wheel on a hard lock off the drive - definately worse in the cold - i thought it might be something to do with the calipers/pads sticking.ORIGINAL: Alpine
Chaps
started her up this morning, and as I move the steering wheel to pull away , there is a loud knocking noise and a knocking feeling through the steering wheel. Must be something to do with the power steering I'm sure. As I pull away, all then ok.
Just wondered if any one has had this? Can it take a moment for the power steering to pump up, following start up of the engine?
