Power steering
- Thread starter devans
devans
1. Are leaks with the power steering rack fixable
2. How easy is the power steering rack to remove and fit back.
3. Any ideas on cost of a new/ replacement rack
4. Best place to buy one
many thanks
devans
1. Does the rack have to come our to effect a repair.
2. Can the new small bore pipes be purchased and fitted to avoid paying for a new rack.
Doesnt look like I'm going to be able to tackle this job as access is nigh on impossible
thanks
devans
does anyone have the worksheet on how to remove the steering rack please. I'm assuming that somewhere along the line the larger pipes run from the front of the car to the engine compartment. I'm stuck on where to disconnect this run also. Hoping the worksheet will give me all the info I need.
HELP please!
kasspa
These can be 'made up' so why can't the same be done for what you need?
I had an advisory several years ago that the 'crimps' on my power steering hoses were 'corroded' but hoses were not swollen or leaking.....
Richard advised me that hoses were between £110 -£170 + 2-3 hours labour.....
Jubilee clips were placed over crimps & are still doing there job!!
devans
devans
Anyway, I don't have the tool to split the steering arm ends from the joint at the wheel. On my 944 I milled out a metal wedge with a slot through it. Hammered this in place, which then split the joint. However, I think the threaded stud on the 996 is a bigger diameter so won't fit. Are there any tips that will help. Failing that, I might go to a local garage and see if they will lend me a tool for the job
Also, another trick I've found is to put the wheel back on and lower the car, so the damper takes load and then a sharp blow to the carrier. This is usually enough to release load on the track rod. Heat would be last measure if you want to preserve rubber boot.
