fil911carrera
Hi guys, I have a problem with the electric window on the passenger side. The driver side window works just fine.
When I first got the car the window was working ok but stopped all together later on. After stripping the door I found that the mechanism was a bit rusty so I cleaned it up and lubricated the lot. Turns out that the original motor works fine. The problem is that it will only close the window. I thought that the switch must be faulty, but I swapped it with the working one and it will still only close the window.
Did anybody have a similar problem? I had a look in Clark's Garage but had no luck finding an answer
Please someone help.
