I would appreciate it if someone could tell me EXACTLY where the relay for powered windows is located. I have surfed the web and the best answer I can come up with is that it "is under the dash on the driver's side". As the answer came from an American site, I assume that it is somewhere on the LHS. The car has always had an intermittent problem with the windows not working and for some reason it has now gone solid. I have done the obvious things like checking the fuse and I know the switches are ok. An accurate wiring diagram would help. Is there anything better than the Haynes Manual?
Thanks,
John Bradbury
Thanks,
John Bradbury
