PP Article
Thanks Brian, the only disappointment is that I wrote it back in June last year, at which point that was the ONLY BRZ in the country, and as such was a bit of a scoop. Shame it took so long to get into print, but better late than never.
By the way, since writing it, I have also driven several of the Toyota versions, which have slightly different spring rates apparently, and are probably better set up for UK road use. (removes anorak [:D] )
Wish I had known and I would have taken my PP out of the wrapper before hitting the bin this month ;)
[:D][:D][:D][:D] This article was good and apart from that it was just the usual photo of Alan and a few adverts.[:)][:)][:)]
ORIGINAL: GreigM
Specially for you Greig ... here's one I made earlier! [:D]
http://www.arthurlea.com/Stories/BRZ/index.htm
