sbloxxy
Another Sunday rolling around under the car, this time investigating a knocking noise coming from the front nearside. It turned out to be one of the two bolts that holds the wishbone to the floorpan - it was so loose that I could unscrew it using only my fingers. When I removed it, the threads were badly worn, caused I suppose, by the fact that its been moving around for some time. While I can easily replace the bolt, I'm worried about whatever it screws into; is this a captive nut? I'm concerned that if it is and its threads are also damaged, it will be a pig to replace. Someone please tell me I'm worrying about nothing...
