matthewb
Hi chaps
DOES ANYONE KNOW HOW AND/OR WHO COULD CLEAN-OUT MY HOLLOW SPOKE FRONT WHEEL?
I bought my 993 C4S second-hand - two and a half years old with 45k - from an OPC.
I had my wheels reburbished about 2 years ago. During the process, it was discovered that one of my front wheels was not a standard solid spoke wheel (as the other front and the two rear wheels are) - it was a hollow spoke 'Technology' wheel.
I decided that I should replace the front hollow spoke wheel with a standard-spec solid spoke wheel to balance things up - there is a couple of kg difference. However, no solid spoke wheels were available at the time although a good-condition hollow spoke wheel was - so I now have two hollow spoke wheels (993.362.136.00 - ET52) at the front.
Once on the road, however, wheel wobble became apparent at around 55 mph (with the problem occuring again, I assume, at around 110 mph). I had the wheels rebalanced. Still wobbled. Had wishbones replaced (bushes were a bit worn). Still wobbled. Had forum discourse with Maurice (didn't mention to him that one of the fronts was a reburbished hollow spoke wheel - didn't then realise the significance of this) who recommended having them rebalanced. Gave up.
Some days OK. Some days not.
Then I read the article in the latest club magazine on hollow spoke wheels. Eureka. Of course. The valve hole probably hadn't been sealed when the wheel was being reburbished and the blasting medium (sand, glass beads, whatever) had therefore got inside the hollow spoke and rim spaces, and was freely moving around inside. This would account for the ineffectiveness of repeated wheel-balancing.
Recently things have been a bit better. I think some sticky gunk or scrod must have got inside the wheel, securing the blasting medium in one place thus making wheel-balancing feasible. Still not happy, though.
PLEASE - DOES ANYONE KNOW HOW AND/OR WHO COULD CLEAN-OUT MY HOLLOW SPOKE WHEEL?
I hope the following information is useful and complements the aforementioned Porsche Post article...
[blockquote]Hollow Spoke "Technology" wheels (smooth back):
993.362.136.00 - ET52 - 19.95 lb (front)
993.362.140.01 - ET65 - 23.36 lb (narrow body rear)
993.362.140.00 - ET40 - 25.13 lb (wide body rear)
Solid Spoke "Turbo-look" wheels (ribbed back):
993.362.136.01 - ET52 - 25.57 lb (front)
993.362.140.04 - ET65 - 29.32 lb (narrow body rear)
993.362.140.03 - ET40 - 31.08 lb (wide body rear)
[/blockquote]Thanks
Matthew
[/blockquote]Thanks
Matthew
