Problem with sidelights
RichardF
My offside sidelights front and rear are not functioning when the headlights are switched on, either to dip or full beam. Makes no difference whether the engine is running/off, or if the handbrake is on/off. If the headlights are off, then the sidelights work. Not a fuse issue as they wouldn't work at all if that was the case. Could it be a problem with the switch? Any other ideas?
main light switch I think - mine had very similar weird symptoms on an intermittent basis and a new switch fixed it. Cant off hand remember the cost - had the OPC do it and seem to recall it was circa £150 fitted?
