Problems to expect with high milage 996' s
- Thread starter Guest
Chas are you around? Can you tell us?
I don' t think they have the same oil seal problems as the boxsters but I may be wrong.
Regarding Brian' s comments my first Porsche was a Boxster S and it was fantastic but after 4,000 odd miles and a bunch of track days I have to say I do prefer the 996.
Happy hunting
Grant
Also there are wise words about going for a Boxter S first after your TT, although the Audi TT is great car the Boxter S is faster & a better drivers car, plus you wll have a drop top...have a test drive, but ask for an overnighter if possible, to give you more chance to get to know the car .Best of luck.
I was just being politically incorrect..... as per normal. The 996 is a fine looking car and I dare say I will have one at some point.
Vorland,
I see you have an Audi TT. I have a turbo quattro on the drive at the moment as a buddy of mine smashed his leg this afternoon. He went off in a helicopter doped up to the eyeballs and I' m taking his TT over to his place tonight. My first impressions of the TT compared to the Boxster are that the driving experience is a bit unusual. You don' t " wear" the car as you do with the Boxster but there are a few toys I have found such as the electric wind deflector and easy to close boot. (try a TT guys and you' ll soon know what I mean). My serious advice is to try both the Boxster S and the 996 before making your mind up. You will enjoy them both.
fine looking car
Although the " looking" part is important, I think it is the " going" and " stopping" parts that are the best, together with the " going around the corner" part.
Having an OPC check it will show up normal wear and tear items as well, discs, pads, shock absorbers, etc. I don' t know if they can tell from the outside how much life there is left in the clutch.
Do they do a compression test so you get an idea of the condition of the engine?
You might like to consider how the miles were accumulated. Trundling around motorways puts the least stress on a car generally, since it is not working hard and is warm most of the time, frequent track use will be harder on it, but all bits are changeable and it is there to be used (and is designed for it).
Have a look at what bits have been replaced.
This weeks Autocar seems to indicate that they might?
You are absolutely correct about the best bits.
The Boxster has the engine mounted further forward so the weight distribution is pretty much optimal. The brakes on the S version are the same as the 996. With regard to handling, I don' t think it is possible to improve the going round corners part either, the Boxster is anchored to the road. Is another £20k for a 0.3 second improvement on the 0-62mph time and another 9mph at the top end worth it ? Plenty of people think so and I' ll admit that if I' d had the cash, I would have bought a new 996. You pays yer money.....
(data taken for the Carrera 2 from GT mag so argue with them and not me !)
Have you decided on a C2 or a C4?. From personal experience with my C4 - 49,000 miles at purchase (not sure how or where the car did its miles) the pre purchase inspection found 2 serious (quite expensive) items.
The rear main oil and inter seals were leaking badly and a nasty squeak from the NSF showed a worn lower arm ball joint (front diff seals were also leaking btw).
When replacing the rear seals the clutch was also found to be worn as the C4 tends to be a bit clutch heavy I was told. As it was in bits the new clutch was a no brainer.
The car was sorted and has exceeded my wildest dreams (apart from that dream about Kylie Minogue, the policewoman and the sheep of course) and has not used 1 drop of oil in a year/10,000 miles. Only snag is the OSF is making a similar squeak so new ball joints for the other side looks on the cards.
996 or a Boxster??. Who raised that issue??? No question for myself... I' ve always wanted one. When I bought my 944S2 the salesman said that I was now on a road that had but one direction and it ends here he said pointing at all the gleaming 911' s.... He was dead right!!!
Ah of course I might have guessed... [8D] Brian (I drool over my Boxster S) Fraser summed it up - If he had the money he would have bought the 996!! [
Now, where' s that article on the new GT3RS.........
Grant
I think that I will go for a lower milage example even if it costs a bit more.
The saving made on a higher milage example can be wiped out by a problem or problems that can occur during ownership. I know some of the bills can be very high.... by looking at many 996' s for sale.
Paul Fraser
steve lyden brown
Perhaps I' d better make my next car a DB7 after all !
Steve.
I remember that Jeremy Clarkson remarked that early DB7' s were put together like Mr. Potatohead. While that maybe overly harsh you have to acknowledge that new modern cars have much more complicated designs and options available that mean the liklihood of things going wrong will increase.
Even in an age of mass production you will still get cars that cause more problems then others.... just a matter of doing your best to make sure that the car you purchase next is in good form.
Good luck with your choice....
I am not at all sure that I haven' t been put off altogether
Don' t be.... After all the pre purchase issues were sorted out I have just completed my first year and a service - a ' minor' one at that - Rear number plate light bulb and lower arm ball joint. Fairly minor stuff.... Major sevice due at 24k/2years can' t be all bad.
I haven' t put a drop of oil in it in 12k miles, it drives beautifully, including LeMans at a stupid rate of knots there and back.... and I normally drive it " briskly" !!!
Grant
oldtimer
By coincidence my wife has a Mercedes C250TD made in same year and month, just a different suburb of Stuttgart, which has had more replacements / repair work...less tyres though.
I guess like all mass manufactured items you can be unlucky and get a bad one with faults, and the few 996s that have problems get all the publicity. The good news for people buying secondhand is that there are lots of 996' s to choose from, and their prices are depressed compared to 993' s. The early 964 also got a less than fair reputation for problems that depressed prices even for ' sorted' later cars.
steve lyden brown
You are right about the 964' s reputation, at one time I actually stopped reading messages posted in the 964 Forum because they worried me so much- how come everybody else' s 964' s were problematical, but my one never was ?
All in all, I am very lucky with my cars ( I run quite a few, including a 308, and even that has been good to me----so far ! ). My everyday wheels are a 1989 Alfa Romeo 164 V6. It has notched up nearly 200,000 miles on the same mechanicals as it had when it rolled out of the factory, and it still drives like a dream. Even the tinworm is minimal !
What I am saying ( I suppose ? ) is that I take the most severe pains to get a good ' un when I buy my cars. I takes time and money to scour the market for the best one' s, but it saves grief in the long term. I also never EVER buy a new car. The last new car I bought was a " E" Type V12 Roadster that I bought in 1972, and I am still paying off the credit card bills for servicing and maintenance on it 30 years later ! ( or maybe it is it' s petrol bills I am still paying for ? )
Steve L-B.
Mark Davies
First Service at 10,000 miles - Sept 2002
Intermediate engine oil seal (I dont think it was the RMS) and clutch replaced under warranty. I thought that' s strange these cars are supposed to last forever perhaps I' m just unlucky.
Second Service at 20,000 (yesterday)
Rear Main Oil seal replaced under warranty (£800 if I had had to pay for it). I am also told by the OPC that clutch is 85% worn so I might as well put in a new one as the engine and gearbox is out. Err... but it was only replaced a year ago and has only 10K miles on it, I say to OPC so replace it under warranty. No its a wear and tear issue says the OPC and that will be £400!!!
I am currently in discussion with Porsche Customer relations about this as I cant afford a new clutch every 10k miles, and I am a bit nervous about the oil seals (are they made of tissue?)
PS. I ran Boxster for 20k miles and didnt use up 1 clutch let alone 2, so I dont think its me.
I am dreading the next service bill.
Mark
