Mr.FixitNorm
Hi All,
posted this in the HVAC temp sensor post by alas no replies so I thought I'd try a seperate post !
My 944S doesn't have A/C but has the traditional blue to red temp dial, trouble is when I alter the dial the air coming out of the vents is either stone cold or volcano hot ! When I change the dial the transition from heat `on' or `off ' is precluded by a click from somewhere behind the dash and what sounds like a servo operating.
What I need to know is if there's any form of temperature thermostat that should be operating ? On other cars I've owned you adjust the cab temp by mixing air from the heater matrix with external cold air, usually by mechanical means, this doesn't seem to happen on my 944 and it's getting anoying having to constantly switch the heat on or off all the time.
I've checked the original Porsche PDF's and the Haynes manual but because they all show the A/C as well it's difficult to identify any sensors.
Any help would be most gratefull
Cheers,
Norm
Cheers,
Norm
