The Link MAP kit is very different electronically to the bespoke solution employed on Andrews car. As a consequence the majority of Monday was spent establishing the best way to handle the Link system and how to work with its idiosyncrasies. BKE spent a considerable time on the rollers (poor devil) though, ultimately once familiar with the kit, the final dialling in was done easily within a couple of hours.
Currently, BKE is running nice and smoothly, with all the original tick-over issues resolved and with fuelling set up for 15 psi boost. Guru Racing suggest claims of 260 rwhp with 300+ lb-ft torque at this setting on a 220 Turbo. BKE produced 259 rwhp (280 at flywheel) though unfortunately we couldn't get a torque reading "˜cos it was bust. Bearing in mind this is with an 160k mile 220 turbo at 15 psi this isn't a poor result so far and there seems to be capacity on the injectors to push towards 18 psi. We saw a nice even power curve though it seemed to peak and die a little more than would be preferred which could indicate a shot turbo. [
"So far"¦" we are looking at this as Work In Progress as we are keen to gain more first hand experience. We want to know if the original lack of "Plug'n'play" was due to a problem with BKEs box, or if a degree of dialling in is necessary as a standard precaution. We are also looking to see what torque is being produced, where, and how much more can be gained.
On the road, to me, BKE doesn't seem that different to the original Guru chip setup. Belinda, on the other hand, thinks he is much faster. I haven't had much time, or clear roads, to play at the moment so I will report further as time goes on.
Due to the time spent learning the system on BKE we didn't get time for Graham and Rick to run and hone their big turbo, big injector hybrids. We were thrown out at 11:00pm, so can't give final power figures for their cars though it is anticipate they will ultimately be big.
