Promax stage 3 kit
- Thread starter DavidL
Suffolk944
Moderator
Faced with all that I have been building things up bit by by with the Level 2 kit and then adding EBC, MAF and bigger injectors. So all thats lacking now in terms of the L3 kit is the new turbo plus things like the HG and AFR gauge etc. I got the MAF plus EBC in an attempt to reduce lag and maximise the power curve as much as possible without chasing headline BHP figures. As it is my car puts out 300+ horses. A bigger turbo ala the Level 3 kit would increase lag and for road use I am not convinced that will be of much benefit beyond bar room bragging about power outputs. If I was going to track the car then it would be another matter.
The expense of the jump between a L2 and L3 kit for an extra say 50hp is ALOT. The 50hp that a L2 kit will gain you is less than a grand, that next 50hp is as already said around £3-4k easily [&o]
The L2 kit is excellent I would reccomend you start with that and then see how it goes from there (and what your budget can stand !)
Just my tuppence worth based on what I have looked into before. [
Five thousand GBP for his kit?? I thought it was about $4k US?ORIGINAL: sawood12
Promax gear and service is good, but for that price look at the Vitesse kit. A little bit more for his stage 3 kit (say £5k), but, assuming your engine is in fine fettle, good for 350bhp at 15psi (allegedly).
Diver944
ORIGINAL: 333pg333
The Vitesse kit would be around £3800 GBP after shipping, taxes and VAT but it doesn't include a wastegate or any boost control like the Promax L3 does. I can't see the Promax kit being as much as £5k, maybe AndyE could post more details, but if it was £5k I'd stump up the extra bit more and go for L4 and over 400bhp [8D]
David, as you are in Wiltshire you ought to take a look at JMG in Bournemout as they are a lot closer to you http://www.jmgarage.com/modify/modify-944.htm and to complete the list of upgrade suppliers ther is also www.lindseyracing.com in the States
Suffolk944
Moderator
sawood12
ORIGINAL: 333pg333
I think so - i'm talking the full level 3 kit with the turbo and not just the MAF kit. The $/£ exchange rate is not as good as it used to be (has been near as damn it 1 for 1 and maybe even less by the time you take into account tourist rates). But at least you know it is going to deliver and be spot on immediately.
