PSE/Exhaust Rattle 2011 997.2 C4S
eastwood1875
Occassionally (but more often than not) on idle/under mild acceleration.
Turned out to be a thin gauge aluminium heat shield just a little bit close to the top/leading edge of the off-side cat.
A quick push out the way towards the front of the car and all is fine.
[8D]
Ha! I was just going to say to check that!
I had similar issue after I changed my spark plugs etc... Turned out I had pushed the heat shield in slightly, so when the exhaust moved it would rub against it. Mine was like a squeaking noise.
