PSE?
- Thread starter c2s
I had sports exhaust on my gen 1 997 C2 which was worth the extra but not on my current gen2 C2S. Have driven a gen2C2S with sports exhaust and do not think it worth the money.
Enjoy the car
ORIGINAL: pikeynet
No, it doesn't come with sports chrono plus, it's an extra.
If your car has it, you will have a button on the dash (next to the PASM button) and if you look at the exhaust one of the pipes will be smaller than the other (on each side)
thanks will check that, I do have a sport button when pressed another button is on also.
http://www.autoatlanta.com/life/vin/vin.php
I got it from a thread on Pistonheads and it seems to work well. Type in your VIN and it gives a very comprehensive list of spec, code numbers and a description.
So if you have one pipe larger than the other on each side then you should already have PSE.
You can check the options sticker in the service book for 'XLF', but PSE is available as a retrofit so your car could still have it even if it wasn't fitted at the factory.
With PSE there are two exit pipes coming out of each muffler (one for each of the four chromed tailpipes), otherwise there's just one pipe and the twin tailpipes branch out from that one pipe. You can easily see this if you look under the back of the car.
Another way to check is to look in the engine bay, just to the right of the steering fluid reservoir (where it says 'only Pentosin CHF11S' on the cap) - if you see a little grey item with a brown plug connected to it, you have PSE.
If you have the Porsche warranty then PSE is your only option, anything else would invalidate the warranty (including the bypass pipe modifications offered on eBay).
If you don't have the warranty there are lots of aftermarket options but if you're only after sound the 997.1 PSE is pretty good.
HTH
Now according the extras on the VIN no sports exhaust is fitted.
Yet I do have one chrome tail large at each end on each exhaust tip, also I have an I code registered to the VIN that porsche dont release to the public.
I telephoned them and asked why and got through to someone who I had to fax a copy of the sales invoice and logbook to porsche to prove I own the 997s.
He rang me back and told me the I is a retro fit code but he needs to dig futher to see what it means, sometimes next week as those are not available.
I am hoping its a sports exhaust either I have one or the S has a pretty mean standard exhaust system.
Clewsey
I was mixed on the GTS but to be fair Bournemouth traffic didn't help me get the most from it [
Cheers,
Simon
This'll never be a specialist subject for Mastermind but I assure you that the standard exhaust on the 997.1 Carrera S always has equal sized tailpipes (you can choose finishes but they're all the same size, I've copied a pic from the 997.1 sales brochure). Only PSE has the unequal-sized tailpipes.
There are a couple of reasons why pressing the sport button wouldn't make an audible difference:
1) The valve actuators on the mufflers are seized
2) The plug has been taken off the solenoid valve or the vacuum line is blocked
PS: The uneven-sized 997.1 PSE tailpipe trims aren't interchangeable with the standard ones. The PSE tailpipes only fit the PSE muffler, as they fix to the outside exit pipe, whereas the standard trims are a 'Y' piece and fix at the centre to the single exit pipe of the standard exhaust.
Never invite me to a party, I could bore everyone to death.
I bow before your considerable knowledge.[
If the plug has been taken off the solenoid it's in permanent "loud" mode, yes? Fairly easy to spot - if you know where to look
