PSM & ABS FAILURE
- Thread starter Grant
PGAdamopoulos
Funnily enough, yesterday after I pressure washed mine, and the undercarriage, to wash away any salt deposits I took it for a drive to dry the disks and I felt that my brakes had gone rock-hard and failing.
I parked it in the garage and couple of hours later I checked the brake fluid level & I took it for a drive. All seemed OK.
Also I have noticed for the last couple of cold spells that the coolant red light comes on on start up, but it goes away after a few miles
lee fulford
Mine does the same everytime I wash the wheels. A drive down the road and a good few hard applications of the brake pedals sorts it out.
Grant
ORIGINAL: dparslowIt will probably be one of the ABS sensors playing up or just covered in dirt.
Covered in dirt is likely!!!
My silver car looks cocoa brown at the moment, with grass taking root under the wheels arches!!! Must clean her, but don't have the heart at the moment as 1 mile later she will be brown again!!!
PGAdamopoulos
I think you must be right now thinking about it, because it was the 1st time I pressure washed the undercarriage and wheel arches/disks/calipers.
I had the same problem with the PSM and ABS failure light coming on today on my 996 t, I stopped the car after I got to my friends and restarted her and the warning light just switched off., no problems on the way back home. I was going to phone up my local porsche center tomorrow because the car still have a months warranty on it, anything to be concerned about?
Edward
Grant
ORIGINAL: Edward
Hi Grant
Edward
Hi Edward,
In honesty I haven't done anything about the issue as it hasn't popped up again. Knowing how expensive these things are to fix, best get yours checked before the warranty runs out. Let us know the out come, perhaps you would be good enough to post what the OPC says.
But I still dont understand why the PSM light came on! Have to give them a ring tomorrow.
