Pulling to left on braking
- Thread starter Guest
adamtsobek
Adam
Richard Savage
Amolak - Totally agree with Adam's diagnosis as a possibility, you may well have a 'lazy' caliper, but don't neglect to check the simple things first. Tyre pressures, tyre wear, tracking maybe!ORIGINAL: Amolak911
Hi,
What would cause the car to pull to the left on braking.
thanks
Amo
R.
Richard Savage
Amolak - Yes, there's a very reasonable chance that they can be 'fixed' by stripping, cleaning and fitting replacement seals and without the need to replace the complete calliper unit, but you will need to take advise on that, since it will depend on it's overall condition.ORIGINAL: Amolak911
Hi,
Will get it checked out soon.
Can the calipers be fixed?, or do they need to be replaced?
If so what is the cost?
thanks
Amo
Discuss the problem with who ever is going to sort it out for you!
You will almost certainly be advised to have the brake pads replaced and possibly the discs. You may also be advised to have the brake fluid repaced. I don't know what documentation you have but you might care to check and see if / when the brake fluid was last replaced.
Cost. Difficult to say. It will obviously depend on how much work has to be done, hourly rates, cost of parts, etc. Discuss it with who ever is going to do the work and get an itemised estimate.
R.
ORIGINAL: Amolak911
Hi,
I have just noted that on the rear wheels the spacers are different sizes. The right is 75mm and the left is 50mm.
Could this cause the problem?
Amo
Yikes [:-]
From an earlier thread, am I correct that you are running 18" wheels on a 3.2 Carrera [&o]?
You may well find that, under braking, the wheels are following the camber of the road - ie pulling to the left.
