scam75
Well-known member
Morning All
You may recall I swapped out my drive shafts complete with new CV's when I had all my gearbox trouble (about 6k miles ago), as it happened my original shafts and CV's were not the problem. ECP supplied me 2 complete shafts and joints for the princely sum of £90 a side. This was discussed at the time and there may have been a sweepstake among the detractors about how long these things would last! Well we got the answer yesterday, 6k miles before a catastrophic CV failure. Accelerating in 1st away from a junction as I passed through about 4k revs the inner OS joint disintegrated!
At first fearing a gearbox failure, as I lost all drive, I was a tad crestfallen. Cruised to a halt and noticed that car behaved properly with clutch engaged in neutral and breathed a sigh of relief. Stuck my head under the back to see a grease packed ball bearing staring at me and noticed a few others along the path I trundled to a halt on! There was nothing at all left connected to the output shaft. Luckily was only half a mile from home so got the car recovered and got to work. Once I got the shaft loosened and removed a further 4 grease covered balls fell out the outer joint! Dug out my old (perfectly fine) shafts and refitted the OS one. Test drive gladly confirmed nothing else had suffered any damage, phew!
The NS shaft is still intact but ran out of time to swap it out, but will do it in the near future.
So it was either a defective joint or that the Q Drive stuff is just made of Plasticine and balsa wood and not fit for purpose. I suspect the latter.
I shall contact ECP and see what they say. My receipt tells me June 18 they were purchased so chances of any recompense are slim but 6k miles is a joke.
Steer clear of these products chaps!
Stuart
Stuart
