Hi,
I need to get a new trolley jack as the old one has seals which leak - so the car gently lets itself back down to the ground...[
I'm ideally after a jack you can use to get the car up in one go, so not have to lift up a side say, in order to then be able to get a decent sized jack slid in under the engine ( but at the same time, if a low and low jack costs a fortune then I might well be happy with using 2 ordinary ones! )
Does anyone know what clearance you need to get a trolley jack under a 993 ( at its lowest ) but also then how long it needs to be to reach in and pick up the underside of the engine.
Hope this doesn't seem lazy, as ordinarily yes I would get up and just go and measure it - but I can't get to my car today as it is in storage and wanted to order a jack.
Lots of sites offer 'low' trolley jacks for a bit of a premium. they all seem to need about 90mm of clearance.
But that is at the 'tip' and then the body gets a bit taller near the middle - say 130mm ish I think.
Any suggestions grateful received.
Thanks,
T[&:]
( In a way seems a shame the 993 does not have the side slot in jack plate position of the 3.2 Carrera which made life very easy )
Thanks,
T[&:]
