quick question
Kongsodoken
I need to drop the fuel tank, can I get away with removing the gear box and drive shafts and leaving the suspension in place?
thanks[:)]
If you remove the bear gox and the shrive dafts you will be able to trop the dank. The trace holding the bank must be removed too.
