924Srr27l
For those that have a Daily or occasional use Road & Track Day car and with only
one set of wheels and using R888 Tyres and any track orientated tyres can be a risk on the road (And track!) in the Wet.
The tradeoff of having a semi cut slick tread pattern (more rubber in contact with the tarmac) and not a tyre with many channels, grooves and sipes
is the lack of water drainage (pumping) leading to aquaplaning but also a lack of multi tread blocks offer less movement / feel & give so a semi slick is
only at it's best in the bone dry on a warm day.
The other technicality with Track tyres is the Compound which the (Treadwear Rating) can be used to give you an idea how soft or hard a tyre is.
A R888 Toyo is Rating 100, a Michelin Pilot Sport 3 Road tyre 320 and other budget brands can be 400. The softest will have the best COF (Coefficient of Friction)
but will wear out quicker as the rubber rolls off with hard circuit use and a trip home from the track may turn out ugly if the tread depth is below 1.6mm or it's raining!
A higher Treadwear rated track tyre will give more longevity and one with more channels offer better safer performance in the wet (Road & Track)
There are now a few alternatives to the R888 and I'm sure many members have tried several makes, I'm currently testing some NANKANG NS2-R tyres
on the road with a view to driving to Sprint / Hillclimb events.
They have 3 central channels for water dissipation and a treadwear rating 180 so they are probably not as good as a Toyo on track but could be a great compromise for multi use. They are also less expensive than R888's
I tried 2 fronts 205/55/16 (34psi) for a run last night in the Wet (North Wales) and there were no major drama's , turn in and braking all good.
I'll report back on their performance when I get a dry run.
data:image/jpeg;base64,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
R
R
