Hopefully a friendly 964 owner can explain/show how the factory ran 3 point belts with the RS seats.
I have most of the puzzle solved for my Recaro Pole Position seats including using a couple of RS bits and pieces in the install. For track use I have a good 6 point harness set-up but there are times when I want to use the 3 point belts. The last problem to solve is that the OE receptacle for the belts sits up too high for the 3-point to fit thru the hole in the side of the seat. You can just see it in the photo below. If I use the 3-points I have to run the belt over the side of the seat before I clip it into the receptacle and from a safety point of view I think this is less than ideal.
Does the RS have a shorter "receptacle" (is there a technical term for the receptacle???)?
Many thanks,
Richard
Many thanks,
Richard
