Couple of hours to spare today, so decided to remove the front PU to take a look at the rads. There are 5 in the front of the Turbo S - 2 in tandem either side of the central.
Even with mesh fitted over the front apertures, there was still plenty of fine debris lodged in the corners of the rads and this is where troubes start as this material tends to hold in the moisture, leading to corrosion of the alloy matrix and eventual leaks.
So loosening off the front rads, I blew all the crud away with a high pressure line then treated the rads with some anti-corrosion fluid before fitting everything back together again.
Job done and this should keep everything shipshape - for while least. [
Regards,
Clive.
Regards,
Clive.
