radiator fan
NEIL2
Hi 1991 S2 did the same with low batt voltage , if i hit defost button on and off it kills fan ? dme thinks my car has aircon as its late s2 with twin fans , does this as soon as temp about 1/3 on gauge but ok if hot or cold ??????????? low volt fan clears on restart
can I just run this past you, not sure if it is a problem or not.
when I come to start my car in the morning (with a cold engine), there is no sign of the radiator fan coming on when I turn the ignition key.
However, when the engine is warm (not necessarily hot), the fan comes on when I turn the key, and presumably stays on while I drive (although I can't really hear it running over the road noise etc).
I understand there are 2 fans, not sure what one does over the other, but does it sound like I have a problem, and if so, what is the cure?
