Stevenash56
LStarted a journey to attend a regional meet today and 15 minutes into the journey my water level warning started to flash. Always check levels meticulously so this was a bit of a shock. Stopped on the side of the road and when I walked around the front of the car I noticed water coming from the front passenger side this had the green tinge to it so I knew straight away that either a hose or the radiator had sprung a leak.
Went straight back home stopping at a garage 5 mins away to check the level so no damage was being done.
Scanners out and dismantled the front end which i couldn't believe was very easy. Anti freeze and water all over the wheel arch and discs ect.
I couldn't believe the amount of debris that had found its way into the radiators not only the bottom but the top as well This included cigarette ends , leaves, and dirt.
I found the leak which as Sod's law goes was 3 pin holes in the cooling radiator right at the very top, I would have thought that if it was going to hole anywhere it would have been the bottom.
I Need to replace the radiator and while the front end is off I will be cleaning every nook and cranny from debris.
Would it be best to change both sides?
http://i1281.photobucket.com/albums/a503/Stevenash56/radiator/7e11385b2aa80916fc98ed2388d94816_zpse97fff75.jpg
