Radiator Replacement
Merry Christmas all 996 owners.
Does anyone have a good set of insturctions of the replacement of the two main radiators on a 99(T) C2 Cabriolet?
Porsche bless us, everyone one [:)]
If you join the club you will get access to all the techncial write ups for DIY jobs which includes radiator replacement. Best £66.00 you will spend, if you are already a member you need to get your membership number linked to your forum user name to get access to all areas of the site.
I do have full membership, but seem to be having problem with the status (guest etc). I have downloaded Min's Centre remov/replace instructions. Does anyone have any experience/instructions on remove/replace of the two main radiators (C2 Tip). In addition the hose clamps, and idea of a good place to get them. I have typed it into search engines, but get all sorts of stuff that is not what I think I need. Thanks
Interesting. I saw your post in this thread: http://www.porscheclubgbforum.com/tm.asp?m=235860 and the post there shows your status as a club member. On this forum it shows you as a guest. Very odd. I would contact one of the admins to see if they have any ideas. Edit: or should I say it did. When I looked a second time it showed you as a guest there too. Even odder.
