will lyons
Well as if problems never seem to end the temperature sender needs replacing in my radiator slow running twin fan is staying on and not cutting off after the usual 30 seconds or so. If I pull the relay it stops replace the relay and I can hear it switching in so thinking I am correct to replace the pickup/sender in the radiator.
Is this the Turbo the same as the lux in the bottom corner and a long reach 30mm socket ??
another job for the weekend []
