Radiators
- Thread starter bubby
I guess you are already filled now so - Take off the oil and water caps, lift the plastic false bottom below the caps - there you will see a valve, the pin has an excentric pull over lever movement to it, Pull the pin over, replace the oil cap but leave the water cap off, now start the engine, allow it to reach normal opperating temperature and then give it 10 more minutes idling, the air will be purged via the valve.
Switch off, put the lever back in its original position and replace the plastic false bottom, caps back on- thats it - all done
Alex Postan
Not sure if the above post is intended to be sound advice or simply a play with semantics at the advice i gave, when i used the term water perhaps i should have said coolant
