Radio Amp problem (Pics)
- Thread starter Showtime
Either that or it attaches to the screen aerial somehow.
Has your new screen got a fine wire aerial built in to it? It should have. Without going to check mine I think it runs up the centre of the screen (I can't remember!)
ORIGINAL: Mark Bennett
I've not been in there myself, but that looks like it could be the aerial that has been snapped off of the previous screen. I suspect the new one should have had similar to plug in to the white connector.
Non-PCM (Navigation) screens should have a single thin wire running down the centre of the screen as Mark states. Cars with Navigation should also have two extra 'diversity' aerials one either side of the screen. From what I can see on the photo your car does not have Navigation, if it does they have also fitted the wrong type of screen. Either way the wire should be attached to the replacement screen.
I know several members who have screens fitted incorrectly by a well known glass company; Most have had a second screen fitted under direct supervision of a dealer.
My last screen was fitted in USA and the insurance approved company wouldn't touch the screen so I had to go to a dealer to fit it, pay for it myself and then claim back the cost from the insurance company.
However, I am not sure that method is available with UK insurers, and I do not know if UK Porsche dealers actually fit screens.
ORIGINAL: Showtime
Mark.Nick, thanks for the input, appreciated. The car does not have pcm/Nav, but the aerial element does run around from the centre of the screen, up and around to the bottom of the A-Pillar where it termainates at the base of the screen.Its at that I point I think its broken. It;s so tight that I just cant tell if whet's left is old or new.. either way, I think it's a new screen to solve the problem.
You maybe able to get to the connector by removing the wipers and plastic cowl in front of the windscreen.
The metal tab that the wire connects on to is on the bottom right hand side of the screen. If you are lucky that broken one is from the old screen.
Best I can suggest at the moment without replacing the screen is to connect a wire to the connector and run that behind the a-pillar as a temporary aerial.
