radio/cassette
- Thread starter pepe
les richards
The book doesn't appear to give the standard fitment unfortunately.
Have I just told you something you already knew?
The Certificate of Authenticity I requested from Porsche for my 993 lists separately all the options including the radio. This could be a line of enquiry for you if you haven't already been down that route.
les richards
Within the range of options for those years there are over 10 types of audio equipment listed. If I'm understanding the book correctly any of those could be fitted, with no 'standard fit' indicated.
I have a number of Porsche brochures collected over the years covering the SC and slightly later models. These are scant on radio options but peering at the photos Blaupunkt seems to be the fit more often than not. Whether this was specific for Germany I don't know.
Back to the Red Book. The following specific Blaupunkt kit is listed: Berlin, Koln, Bremen, Symphony, Toronto, Ludwigsburg and Boston. Description says 'radio' with no indication if a cassette player is included (but I'm sure you could research that if you wanted).
Added to these there are descriptions such as: Porsche radio, radio Monterey or Reno (no make given), radio Charleston (no make given), Porsche CR stereo/cassette.
So, more information but not much progress!
I seemed to recall something about option code information on a label (same as in the handbook you don't have) on the underside of the bonnet. Worth a look but unlikely to still be there after all these years.
rizzo1
Best of luck with your search
Simon
rizzo1
Cheers Simon
Don Curtin
My 87 3.2 has a Berlin radio cassette.I would have thought that a Sony is an after market unit.
Also the Ariel is fitted in windscreen with a small booster under the bonnet.Sometimes if a new screen has been fitted they forget to connect it up or they break the wires comming out of the screen(that happened to me )If all is working the radio reception should be ok.
