radio codes
- Thread starter tinney
I have a Becker decoder which works in about 80% of cases. Email me the last 4 digits of the serial number, and I'll give it a try for you. I assume it is a CR/CDR-22, and you can get the serial number by:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
Or, if the radio is out of the car the then the serial number is on the label.
Start by trying 4106
Then try 4108
Then try 4107
If those don't work you will have reached the 3-try limit and will be locked out for about an hour.
Then try 4105
And finally 4104
I have also had cases where the code was one digit out in the hundreds.
Also, the code is often recorded in the DME (ECU) data as a backup. This can be read with a Porsche tester. If you are anywhere near me (Maidenhead, Berks) I could read out the data for you.
If you don't get a result you will have to contact an OPC for the code, which they should be able to provide, but may charge.
Good luck, and let us know if you are successful,
