Radio Reception
- Thread starter sailor
Is this normal to have intermittent reception such as I do and can anything be done to resolve it?
Any suggestions appreciated as always.
Think that is the typical time that the amplifier gets either damaged or disconnected. PeteORIGINAL: JB 3.2 Reception on my Becker used to be very good until I had a new screen fitted its now very poor.
jboult
Yep, not sure where the actual amplifier is, but it connects between the screen aerial and the head unit. Heard quite a few tales of it either not being reconnected, or being damaged, when windscreens are replaced PeteORIGINAL: sebrussellsmith Pete you mention the amp getting disconnected or damaged - are you referring to the connection from the screen? Many thanks.
I had the same problem and I too have a Becker. Just been for service and the inde has checked everything and still has no idea. I get Radio 1 OK but the local stations are terrible.ORIGINAL: JB 3.2 Reception on my Becker used to be very good until I had a new screen fitted its now very poor. I've checked the connection to the screen behind the speedo and it appears OK although I've not taken the stereo out yet to check connections at the front end.
I have a Becker Indianapolis. When it was first installed it seemed fine but I was not up to spped with what it did and how. I found it always kept jumping to from one station to another, usually one that had a stronger signal. After reading the manual, something I only do as a last resort, I found that if I set the radio to manual tune, it stayed on the station I had selected, regardless and seems much better. Seems that when set to auto tune they do seem to jump from station to station for no apparent reason, except that the quality of one signal has dropped and another improved with the set selecting the strongest signal. Maybe not the answer to your problem, but just a thought. MichaelORIGINAL: Sam77I had the same problem and I too have a Becker. Just been for service and the inde has checked everything and still has no idea. I get Radio 1 OK but the local stations are terrible.ORIGINAL: JB 3.2 Reception on my Becker used to be very good until I had a new screen fitted its now very poor. I've checked the connection to the screen behind the speedo and it appears OK although I've not taken the stereo out yet to check connections at the front end.
