Ok, a bit more on this.
As said above if the manufacture date is on or before 31/12/85 then you can register it and use it as a Cat 4 Historic. If it's later then some car clubs and rally clubs run the modern 'Targa' class where pretty much anything goes.
However, with all the above comes the following prerequisites:
The engine, brakes (discs and calipers), method of fuelling, gearbox and handbrake must stay as originally fitted.
This means NO power upgrades via chip/remap, no big brake upgrades (only as per standard fit, pads are open though), no sequential box, no hydraulic handbrake and no changes to the injection system inc injector upgrades. You also can't run a throttle cam. Re suspension you can upgrade and strengthen but not change the original design. In this case it means you need to keep the torsion bars but can add a helper spring. Topmounts are open.
However you CAN use parts from after 1985 providing they're identical to those from the pre 86 cars. For example if you shit your turbo you can replace with the same item from an 86+ car. Same for block etc. Changing from a 220 Turbo to a 250 would be frowned upon.
Last point, and it's a kicker - tyres. These have to be a MINIMUM of 65 profile. No excuses and no acceptance from scrutineers. This was a minimum of 70 profile until the end of 2014 and it took the MSA years to relax the rules to allow 65s.
Drop me a pm if you want to chat more on spec and setup.
