ramus Side Repeaters
Ive taken off the side repeaters and it seems they were stuck on with what looks like black mastic ? ive tried fitting the Ramus ones only to find that they are crap and the plactic lugs have snapped off ( my 964 had some from the Porsche shop and they fitted a1) so it looks like im going to have to stick these as well can anyone recommend what mastic ? type of glue to use , rembering all it has to do is hold in place just in case the bulbs need changing and I need take them off again .
Try some Outdoor Sticky patches. They are sticky on both sides. Can be cut to size and they don't stick like s**t to a blanket so easily removed when required.
Steve,
Try Halfrauds, B&Q, hardware store.
They are in a thin packet about 6" x 4" in size. Two sheets, with about 40 squares on each. Lots of uses for them. Should only be a couple of quid. There is an Indoor type as well so make sure you get the Outdoor ones.
Cheers,
ORIGINAL: Fred Hindle
..... don't stick like s**t to a blanket so easily removed when required.
I'll go along with that. I used a whole pack to fix on a rear number plate and it still came off - I assumed it was because of the expansion of the acrylic when it got hot. I screwed the plate on in the end.
