Hi,
I put some oil in the 993 this morning before a run as ai knew it was low-ish, the engine was still cold, but had an idea that i'd be ok with a half litre or so, anyway all is ok, when at operating temp the oil level guage shows around the 1 o'clock position.
Heres the Question:
When i was putting oil in, it backed up slightly in the filler pipe and run down the inside of engine compartment, and ever since its taken two attempts to start the car, on the first attempt it makes a kind of rough knock/chug sound then i high pitched whine???(sounds electrical-ish) ?, wonder if it was the starter motor ???.
After this i turn the key to off, they try to start again, and it starts normally, is there anything i may need to check and clean ie. where the oil might of run on to !, it was starting fine until the oil incident.
Once the car is running there are no problems, drives normally.
Any help please.
Nick.
Heres the Question:
Any help please.
Nick.
