Hi all. I’ve had a ”clunk” noise from the rear when taking up drive from a standstill. Only seems to happen when a bit more spirited pull-off.
l’m replacing my silencers and l noticed that after putting the car on axle stands and then removing the rear wheel nuts (with the gear selector in park and rear wheels off the ground) that the passenger side was solid when undoing the nuts but the driver side had movement as l undid the nuts. l could "rock” the wheel as if there was slack in the driveshaft.
Could this be the "clunk”?
Should there be no slack on the driveshaft?
Any comments welcome.
l plan to check all around when l’ve completed removing the silencers tomorrow.
2002 Tip.
2002 Tip.
