edh
My car is going in for some work soon (clutch, fuel lines, some minor rust) & i think it makes sense to drop off the rear axle to replace bushes while we're at it.. I haven't seen any particular issues, but it would be sod's law that a bush would fail soon after everything is put back together. They are probably on borrowed time after nearly 240k miles.
It's a road legal track car, currently all rubber bushed, KWv3 suspension with clubsport spec springs. No cage, bucket seats & 3 point belts. That gives you an idea of the style of car - comfortable enough to drive across europe, but firm enough to go well on circuits.
There are a number of different bushes in the rear suspension that could be replaced - but with what? OE rubber? (Can the OE rubber bushes be pressed in easy enough?) Worth changing the spring plate cover mounts to solid? Just using this vendor as an example really... http://www.elephantracing...4suspensiondiagram.htm
Oh and before anyone dives in, my car is the best and fastest iteration of the transaxle range, and is near on perfect already with its judiciously selected modifications and weight reduction... [
