Hi there. I have a 2006 Boxster 987 3.2S
The bulb in the rear trunk will not light. I had replaced the original with one that I know work.
When I try to lock the car with the boot open, I hear the horn, so I'm not sure it is the microswitch.
It could be a fuse, but I cannot find which number fuse it is in the manual or online, and if it is shared with any other electrical components, it can't be that as everything else on the car works as it should.
Any ideas as to which fuse I need to pull, or indeed, what else may be causing the problem?
James
James
