Rear brake caliper advice
- Thread starter cococola
chrisg
When you take out the bleed nipple it will be cone shaped - this cone should match the female one inside the bleed nipple ( this has a hole at the tip for allowing the fluid out) - the 'seal' is created by the pressure of the male cone into the female cone. I know it sounds daft, is it definitely the bleed nipple that leaking ?
Notwithstanding the cost of replacement/ refurb caliper - rear brake calipers are worth replacing - they get limited fluid pressure (due to bias) and rarely get hot so sticky/seizing is very common - even on 4 pot Brembo Turbo/S2 versions !
