Rear bumper stays
- Thread starter Guest
clyde
Have you checked whether anything else needs done at the same time or are the 4 stays the only bits that have gone? I haven't been under mine to have a good look but suspect that if these relatively hefty chunks of steel have rusted away there must be other associated bits past their best as well.
I don't understand why they have rusted as they don't seem to trap water or mud and being as close as they are to the engine, exhaust, etc I wouldn't have thought they would have been affected by road spray as they woulf dry out quickly.
A quick summary is; Wheels off,rear part of wheel arch liners off-then unscrew the lights....only the lights not the centre reflector.
Black plastic reflector top cover off.
Unplug light plug in rhs rear corner of engine bay (will become obvious when you pull the bumper away).
Now the bumper fixings themselves;
youve got all the obvious ones right round the bottom lip.
4 or 5 along the top above the reflector strip.
Then 3x8mm headed screws(each side) up inside the wheel arch connecting the top edge sides of the bumper to the body.
Now you should be able to slide it back and away from the car(can get a bit stuck as you pull it back underneath the body where the lights fit.
Hope this helps,excuse my poor typing.
Dan
As I remember, it was a pig to get at the top fixing of the rear support, as it is very tight for space in there. I had the benefit of having the car on a 2-post lift which made it a bit easier. It would make it a lot easier if the rear PU was removed.
clyde
Do you know if there tends to be anything else that needs replacing at the same time? My cars a daily drive and I would prefer to get all the bits before I start.
Richard - my stays have all rotted in the middle, which is why I don't really understand it. They don't seem to trap mud or water at this point.
38F3E1
ORIGINAL: clyde
... Richard - my stays have all rotted in the middle, which is why I don't really understand it. They don't seem to trap mud or water at this point.
Pretty sure it's the heat that causes the problem. It's common on 993 and 964 I believe.
Ian.
Pickled Piper
Put some masking tape on the body of the car just above the PU. This will prevent any scratches when you slide the PU on and of.. It's not a difficult job just be patient.
the stays are prone to corrosion becasue they recieve lots of road spray and also heat from the exhaust boxes. Perfect conditions for corrosion.
oh yes just remembered. once the PU is removed you will get very good access to the heat shields on the exhaust boxes. if these have never been replaced then they will either be broken or have fallen off completely.
pp
Is it a much bigger job to have a go at all the heat shields while doing the stays? I know mine have to be done at some time and the price seems to have gone up from £500 (OPC) to £800 (JZ in March) over the last 4 years.
Cheers,
